Power Acoustic FUBR vs. Alpine Type R
Carter Lassalle
Now i know a lot of you like the Type R's, but the specs on these FUBR's look a lot better tell me what you think?
http://www.bestbuy.com/site/olspage.jsp?skuId=7042032&type=product&productCatego ryId=cat03081&id=1099396539135 vs. http://www.bestbuy.com/site/olspage.jsp?skuId=7057383&type=product&productCatego ryId=cat03081&id=1108124880979
Username: Hdubb
Farmington, Nm Usa
Post Number: 1634
type Rs are better. they sound cleaner and will get just as loud and dont need the power that the fubrs need
Carter Lassalle
You think everyone would agree with that?
Username: Hdubb
Farmington, Nm Usa
Post Number: 1642
99.99999999999999999%
Carter Lassalle
alrite thanks, and do you think 2 of those powered by an Alpine 12V amp would sound very goood
Carter Lassalle
or, if not that what amp FROM BEST BUY, would power those the best
Username: Hdubb
Farmington, Nm Usa
Post Number: 1643
im not sure the new Rs have a 500rms rating so it would have to be a pretty big amp or 2 500w ones. 2 mrp501 would work not too sure if they sell them at best buy, or 2 power acoustik 980/2 kinda like that amp. put it through hel.l. if you could special order the 1001 v12 amp that would be awesome but i dont know your budget(exspensive amp)and i do think it will sound pretty good. just dont buy any qlogic box build your own, you will be happier and you will save money
Carter Lassalle
If i tried to build my own i would definetley skrew it up.
Username: Hdubb
Farmington, Nm Usa
Post Number: 1645
its not that hard man, and they will sound louder and better. trust me. you just have to make sure you measurements are correct and take some time on it.
Carter Lassalle
how would i build it tho,what do i use
Carter lassalle
which of these best buy amps would be the best;
http://www.bestbuy.com/site/olspage.jsp?skuId=6250709&type=product&productCatego ryId=cat03085&id=1069302217970
http://www.bestbuy.com/site/olspage.jsp?skuId=6319637&type=product&productCatego ryId=cat03085&id=1075583127180
http://www.bestbuy.com/site/olspage.jsp?skuId=6983106&type=product&productCatego ryId=cat03087&id=1099388637322
http://www.bestbuy.com/site/olspage.jsp?skuId=6983393&type=product&productCatego ryId=cat03087&id=1099388650996
http://www.bestbuy.com/site/olspage.jsp?skuId=6250451&type=product&productCatego ryId=cat03086&id=1069302293115
http://www.bestbuy.com/site/olspage.jsp?skuId=7168842&type=product&productCatego ryId=cat03086&id=1110266457133
Username: Hdubb
Farmington, Nm Usa
Post Number: 1647
thats a hard choice. i think the first one or the 3rd one why can you only buy from best buy?
Carter lassalle
because my dads best friends son can egt me a huge discount, i will pay what best buy payed for the products
Carter Lassalle
And the first and third one wouldbe able to power the whole system
Carter Lassalle
Username: 54danny54
Post Number: 325
the FUBR's would destroy the type-R's in spl but the type-R's would soud clearer
Username: Phuktupbasshead
Scottsdale, Arizona United State...
Post Number: 28
I had 2 FUBR 10's... and trust me, you don't want these subs if you plan on giving them alot of $hit. I hooked up one to my 900w mono amp - and blew it big time!!! Then, I lowered the input level on the amp considerably and hooked up the other one - and the tinsel lead tore on the sub after about 2 weeks. I'm currently in the process of hooking up an IDMAX10v.3D2 (wish me luck - I'll let you guys know)
xdrummer03
2 Type R's are better than one Power Acoustic. Better sound quality as well as the Type R's sound better. Also best setup for 2 Type R's is 2 of the MRD-605's.
xdrummer03
That would be the best way if you want a 2 amp setup and all Alpine. Kenwood if you know how to bridge the 2 Type R's. If you want the easiest hook up just running left channel to one sub and right channel to one sub get the p8002.
so you guys would go with the type rs then
ive heard some people say they arent that great, but that was in comparison to some JL's
im not sure what i should do
they are each 500 W rms, how do you adequitley power them
would an 1000W 2 chn amp work
or no
thanks
Username: Araknid
BOCA , FL U.S.
Post Number: 649
yeah that would work. make sure the amp puts out 1000 watts at 4 ohms Then buy the 2 type R's with the DVC 2+2 layout. hook each subs voice coils in series and then hook up each sub to its own channel. It would be easier to have SVC 4 ohm but I dont remember if any of them come like that.
