JL QUESTION
strongcola
I have a jl 13.5 w7 but its f u uped and i am sending it back for repair thing is if i get it back should i get another? it as if no one talks about the 13 w7 all the other modles get talked about, is it a trubled sub, see i want mad sbl also want sq is this the woofer to give it? and how would it sound if i ported it?
Username: James1115
Wilton, Ct
Post Number: 3323
that sub SHINES in a ported enclosure vs sealed. There are better subs out there in my opinio for the price you paid for the w7, dont get me wrong I am not knocking JL I happen to love JL and I have run a few different set-ups with their subs but they are on the $$$$$$$$ side. REXXX or avalanche or eclipse TI is another route you might want to try.
strongcola
i have 1 should i get another? i also have 2 15 l5 kickers 2 12 l7 kickers the w7 13 jl 1000 ppi 2400 and the art sires 1200 and a hole mess of other stuff dont know that to run?
