Triple chamber abc box may be able to be slimmed down
Username: Insearchofbass
Post Number: 2524
i think i figured out a way to slim down the box size for my triple chamber abc boxes for larger speakers but it will require a good low pass filter
Post Number: 2525
a good high pass filter i mean
Post Number: 2526
basiaclly a subsonic filter
Post Number: 2529
another good idea may be to port each chamber from the outside of the box then you would eliminate port displacement inside the box slimming the box size to original target volume and you could run the ports around the box and up through the back deck of your trunk
Post Number: 2530
this seems like the overall best approach if it works like im thinking it does
Post Number: 2531
but i forgot you would have to keep the two internal port inside the enclosure still so youd ad that back to your internal box volume
Post Number: 2532
you could use pvc in this case and get creative with your design....header pipes anyone?????with flared port ends lol
