Pyle audio rating, worth getting???
Greggs
on ebay a guy is selling 2400 watt peak total ... 2 pyle subwoofers... i have a 1200 sony amp which would work well because they are dual subs but i don't think it is enough power???
Username: Insearchofbass
Post Number: 2527
honestly id tell you to stay away from the pyle subwoofers
Post Number: 2528
if your sony amp is only 4 omhs bridgable and not 2 ohms id say do two volfenhag 4710 series woofers or two 4712 series woofers
Greggs
the 2 subs that are 2400 watts are for only 60 bucks... and my amp is best bridged at 4 ohms... right now i have duals at 1100 watts.. so i'm wondering if it would be a good upgrade??? i don't want to spend more than 100 dollars for 2 subs that are better then the duals i have now.. and also fit my amp..
Username: 54danny54
Post Number: 324
no pyle sucks man
Greggs
where can i get some cheap volfenhags.... http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18803%26item%3D5778765391 %26%26 is this a good price and would they go well with my 1200 sony amp... 4 ohms stability.. bridged....
Username: 54danny54
Post Number: 326
get a couple kicker CVR's 10's or 12's www.woofersetc.com or find em off ebay
