How would i wire this?
Username: Theceo
Post Number: 44
can anyone one tell me how i would wire 2 6x8s to a mono amp that i already have 2 subs wired to, or can anyone maybe give me a wiring diagram? thanks
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 581
You don't. Run the 6X8's off your headunit until you can get an amp for them.
Username: Theceo
Post Number: 46
so there is no way to run them off my mono amp along with the subs? if i run two amps, wont that drain my battery?
capww8
no, it won't drain your battery... unless you're running your stereo w/out the car on... in which case one amp would be too much.
ditto david's comment... it would be really ridiculous to try and run two subs + two speakers off one mono amp. It can be done, but it would be really dumb.
