I'm gonna have a Eclipse CD5444 and an Apple Ipod...
I need help, if someone can that would be great. My boyfriend and I are looking at getting a Eclipse CD5444 and an Ipod but before we do I want to know if your able to use line in/line out feeds from the back of the head unit or something similar to run the music from the ipod through the unit instead of using the connections apple have to transmit it through the radio waves as that is difficult to maintain a steady feed.
Username: Illuminator
Post Number: 445
If it has RCA-in jacks for the auxiliary input, you can simply purchase a wire that converts the headphone out jack on your ipod to RCA for your headunit...
kat
thank you
