WHAT SHOULD I DO!!!
Username: Sx3
Post Number: 129
For the past week I cant decide wether I want an Avalanche 15" or 18". Of course I want the 18" but I only have a trunk to put it in so I would have to go sealed for the 18" and I could go ported for the 15". What would be better (spl and sq)? I'll probably use a Hifonics BX1000D amp.
Username: Araknid
BOCA , FL U.S.
Post Number: 618
either way they would both be incredible.... It really depends if you want SQ or more towards SPL.
Username: Taylor17
Kopperl, Texas
Post Number: 2039
Yup, I'd prob go with the 18, and go sealed... with the 18's surface area it should make up for the 15's ported box I'd think.
Username: Sx3
Post Number: 131
What would be better for the 18" a Hifonics BX1000D or BX1500D?
Username: 54danny54
Post Number: 387
The avalanche works best in sealed
Username: Bigred2069
Post Number: 10
whats the sound difference in a sealed and ported box?
Username: Sx3
Post Number: 132
Sealed ussually sounds better and uses less space. Ported ussually sounds worse but is louder.
Username: Dat_dude88
THE 18" IN A SEALED BOX WILL GIVE IT MORE BASS AND CLEAN SOUND THAN THE 15".ID GO WITH THE 18".
Username: Sx3
Post Number: 133
Would the 18" be good in a 5ft^3 box?
