What type of wire
Username: Sedrick
York, Pa United states
Post Number: 24
do the make a wiring kit for 2 amps all in one package cause i am goin to power 2 amps and i dotn knwo all the wiring i need
Username: Jaackdeth
United States
Post Number: 434
Check ebay!
Username: Erreertt
Post Number: 27
buy ur wiring kit and with 2 amps its a good idea to run an extra battery for ur system they come with like 13 foot of power wire or somthin liek that all u need is like 3 foot to reach ur battery in ur trunk and the ground is long enuf u can cut in half also the only thing u will need is remote wire which is very small wire no problem with that
the only problem im findin is how to hook up the rc cables do i just get an adapter to allow both sets to be hooked up or what
Username: Shadow1290
Fayetteville, GA USA
Post Number: 85
run at least 4 gauge wire to the amps then split it into 8 gauge wires running to the amp
assuming your amp is made for 8 gauge wire
if you amps are made for 4 gauge wire the run 2 gauge to the amps and split it into 4 gauge when it's about 1 foot in-between the two amps
ETC...
