2ohms/4ohms
Username: Shanmag
Post Number: 21
is there any difference in sound between a 2ohm sub and a 4ohm sub?
if the amp can take both, which is more recommended?
Username: Taylor17
Kopperl, Texas
Post Number: 1983
2 ohms will give you more power from you're amp. An amp might put out 400 watts rms at 4 ohms, but wired at 2 ohms, it will put out 800 watts rms. Ohms doesn't really effect the way the sub sounds.
Username: Shanmag
Post Number: 25
ok cos im planning on getting a jl slash 1000.1 and it says it can take 2ohm or 4ohm.
so if i get 2 500W subs (either alpine type r or kicker cvr), would it be better of getting a 2ohm or 4ohm?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 557
is they are single voice coil then you can get either.... just make sure both are the same. if you had two 2 ohm subs you would wire them into 4ohms... if you had two 4ohm subs you would wire them into 2 ohms....
Username: Shanmag
Post Number: 26
im leaning more towards the alpine's, they r dual voice coil! does this make a difference?
Username: Taylor17
Kopperl, Texas
Post Number: 1987
Jl amps put out 1000 watts rms at 11V to 14V, and from 1.5 ohms to 4 ohms. It doesn't really matter what ohms they are. I'd go with the 2 ohm though... no real reason.
Username: Taylor17
Kopperl, Texas
Post Number: 1988
I like the Alpines better as well, they are the 05 mottles, not the 04 mottles right?
Username: Shanmag
Post Number: 27
well im from australia, so they r the new ones that r out here, model number SWR-1242D
Username: Shanmag
Post Number: 28
and im guessing mottles = models?
otherwise, im so confused
Username: Taylor17
Kopperl, Texas
Post Number: 1991
If they can handle 500 watts rms... then there the new ones. I like them a lot... that should sound sweet!
Username: Taylor17
Kopperl, Texas
Post Number: 1992
lol sorry about my spelling... what are you so confused about?
Username: Shanmag
Post Number: 29
yeh they r the new ones then!
thanx for all ur help :-)
Username: Shanmag
Post Number: 30
haha no its ok, i just wasnt too sure wot mottles meant but i guessed it was models!
Username: Taylor17
Kopperl, Texas
Post Number: 1993
lol half of the time I don't really think... and the other half of the time I just can't spell.:-)
