Need some help!!!!!
Username: Kenny_hammond
Post Number: 94
ok ihave 2 12"w3 subs and i am going to put them in a ported box can anyone help me find one i have the pape telling me the specs on the box from jl but i want one already built so i dont have to build 1 can anyone tell me where to find them on th net?
Post Number: 96
can anyone help me?
Post Number: 97
can one help me and is this a good setup for some deep bass that u can hear far away?
Username: Makenx19
Post Number: 12
Im lookin how much do you want to spend on the box?
Username: Makenx19
Post Number: 13
Here's one http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14945%26item%3D3074421622 %26&ssPageName=WD1V $140 (cheap or expensive depending on who u are)
Username: Byrumjr
Post Number: 259
Most good sounding ported boxes are make for each sub from the subs specs. I don't know where you might find one. If you list the specs for that sub and what you want the box tuned at I will try to find one.
Username: Makenx19
Post Number: 14
same one but cheaper (I think)http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14945%26item%3D5778513261 %26
Internal Volume 3 Cubic FT.
Dimensions 15 1/4" H x 33 1/4" W x 16 1/4" D
hope this helps
