Did i wire this correctly and if not
Username: Tatortot324
Post Number: 16
ok tell me if i wired this correctly if not help me out Ok today i believe i wired my subwoofers parallel i opened up my box and wired 1 of the terminals the whole terminal positive + and the other terminal negative - and wired the + terminal to both of my subs then i wired the negative terminal to both of my subs. Then i took my amp and put both positives in both the black and red terminal on the positive terminal side and then wired the negative wires to the negative terminal side and i also used a small wire on both terminals and put just a connector wire to both the red and black terminals on the postive side and a small connector wire to both red and black terminals on the negative side. Then i bridged my amp. I was told this would bring it down to about 1.5 ohms and bridging it should bring it down to .75 ohms but i really didnt see any change i think it may hit a little bit harder but the main bass doesnt hit as hard as it did. Did i do this correctly?
Post Number: 20
any help?
Username: Byrumjr
Post Number: 250
Try this site. Just pick you subs.
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
