CDT HD63's , will 100 RMS enough for these?
vsvas
i am looking into CDT HD series braxials, specs for these are 180 RMS, i have only 100 RMS at 4 ohms, 200 RMS at 2 ohms for each front channel.
How do they sound with 100 RMS?
Are there any other wiring options to get 200 RMS at 2ohms using these CDT HD speakers?
vsvas
and onemore thing all CDT'are 4 ohm speakers
Thanks
Username: Kklagge
Post Number: 164
Save some money and go with the EF series as you'll be underpowering the HD's by quite a bit.
vsvas
You mean Euroframe , how are they? will there be a big difference in sound quality.
How about Eurosport ES-630? these are 150 RMS.
Username: Kklagge
Post Number: 170
I have the CL-62's (w/the 560 xover), giving them 150rms each and they sound awesome...I got them for $200 through a dealer on Ebay...I'd just hate to see you spend $400-$500 on a set of comps that won't sound anywhere near as good as they could if you doubled the power you're talking about putting to them
vsvas
Thanks KKlarge for your suggestion
