Kicker or mtx
Username: Cenus
Hicksville, Ohio Usa
Post Number: 157
which amp would be better for 2 15inch atlas mtx 801 http://www.woofersetc.com/product.asp?0=362&1=363&3=2168 or kicker kx 600.1 http://www.woofersetc.com/product.asp?0=337&1=338&3=393 i'm gonna wire the subs in parelle to get a 2ohm load. so which would be better the mtx has more power but the kicker is {in my opinion} better quality
DonnyAladam
mtx has too much power.. those atlas's are 300wrms each so the mtx would be putting out 800w.. too much go with the kicker- but theres more amps out there that are chaper but not as good quality
Username: Byrumjr
Post Number: 253
If the subs are 300 watts rms and good subs they will take the 400 watts the mtx will put to it. You will be getting close to 460 watts to each sub. For the money I would take the mtx.
Username: Cenus
Post Number: 158
bump
Username: Skyliner17
Saint Paul, MN United States
Post Number: 176
yeah i would take mtx too because its 800 watts at 14.4v and cars are usually at 13.5v so you'll only get around 700 watts which will be perfect for those subs. but one thing is that the subs should be in a sealed box and not ported because if ported u need amp with subsonic filter and the mtx 801d doesn't have subsonic filter.
Username: Cenus
Post Number: 159
ya i have to go sealed because i don't have room for ported
Username: Cenus
Post Number: 163
any1 else have an opinion on this
Username: Marley289
Post Number: 174
well i would go with mtx just simply cuz thats what i got and i like it
