Help sealing speaker connections!
Username: Kurt_114
Laredo, Tx USA
Post Number: 13
hey whats up everybody, I have some 6x9 pioneers I want to put in my focus. The only thing is that the size for a focus is 6x8 front and rear. Also what can I use to seal the terminals in the speaker by just cutting of the harness that comes with the stock speaker. I know tape doesnt work,should I get a portable welder, what else is out there. Please tell me I plan to do it this afternoon. Thanx
Username: Carguy
Post Number: 3055
A welder? For what purpose? If you want to cut the the stock wiring, then you will either need a crimp connector and tool or soldier. Then use electrical tape to insulate the wires first. Next take a heat shrinking tube over it and apply heat. It'll srink and seal nicely.
