CDT HD 63DT or CDT ES630?
Nara
Hi ,
i am moving from co-ax to components, but i don't want to cut any hols for tweeter, so i came across these braxials, price difference is not much for these, so which set do you guys suggest and any pros and cons?
sure i do have an 100x4 at 4 ohms AMP.
Any help is appreciated.
Thanks
Username: Masse1369
Post Number: 33
those comps like a lot of power, im sure they will sound ok with your amp, but power is recommended. you should look on their website, and find the link about the review on the es-07 line and call don at island sound, he is running a great deal on the comps.
Nara
Anymore opinions
Username: Jonathan_f
GA USA
Post Number: 3985
No cons, the braxials are a great alternative for someone who doesn't want to mount the tweeter seperate. One of the best plug it in and go applications you can get, SQ is fantastic and pretty much guaranteed even in stock spots.
GA USA
Post Number: 3986
If the price difference isn't much, I'd go for the Eurosport, by the way.
