15" Avalanches...1 or 2?
Username: Voodoochilde
Greencastle, Indiana
Post Number: 13
I was wondering how much improvement in spl and/or sq I would get from having 2 15" avalanches instead of just 1. I would power them with 600-800 watts apiece. Space shouldn't be a factor for my civic's trunk either. I also didn't know what kind of box to use for 1 or 2 15's. I was thinking ported for spl with decent sq, but I've been reading sealed is about as good spl with better sq. Can somebody help my confused self out? thanx
Username: James1115
Wilton, Ct
Post Number: 3256
in a civic I can tell you , you would have trouble fitting two. I would go with 1 sealed about 2.5 cu/ft and 800 watts should be great!
Post Number: 14
Do recommend any specific amps to use or a box type?
Username: James1115
Wilton, Ct
Post Number: 3259
I recomend sealed. as far as an amp goes you can use any GOOD amp that is anywhere from 600-1000 watts. I run mine off of a Orion Hcca 250G4 but I think I am gonna step up to the Orion 2250SX and run it at 4ohms with 1000 watts.
Post Number: 16
Thanks for your quick responses and info man, my dial-up can't even keep up with your posts, lol
Post Number: 17
Oh yah, I forgot to ask if you thought I would need a new alternator if I powered it with...let's say 1000 watts. Thanks man.
Username: Nnnnick_b
Nc Usa
Post Number: 367
1000 watts = about 100 amps and car needs atleast 50 in reserve. 175 amp alternator would keep things running smoothly, might as well upgrade to a 250 amp while your at is incase you decide to upgrade.
Post Number: 19
Thanks man, so about 10 watts per amp needed. I get it now. lol.
Username: James1115
Wilton, Ct
Post Number: 3298
its actually watts divided by 12=amps or watts divided by 10 x the amps efficiency they come out to be within a few amps of eachother.
Post Number: 23
thanks for straightening that out for me James...how much would a decent alternator be for enough to keep lights steady and 1200 watts for speakers & a sub (after I get my components)...so 120 or so amps just for speakers, I'm not sure how much it takes to run my 4 cylinder civic reliably though. I'm not looking for an exact answer just a guesstimate.
Post Number: 26
anybody have a guess as to how much a new alternator would be or I even need one. thanx
Username: Rhassler
Gilford, NH
Post Number: 257
I have 1200 watts rms on an amp and 200 ish watts rms on my components. I bought a 200 amp alternator from www.mralternator.com and it works pretty good. It costed me about $225 shipped. you might be ok with a 180 amp alternator though. I'd go bigger, just in case later you wanted to ugpgrade sumthin..... so roughly $200-250 ish for a new alternator.
Username: Suleman36
Post Number: 1351
Hey richard did you install the alternator yourself and upgrade your big 3 wiring also ?
Username: Rhassler
Gilford, NH
Post Number: 258
Yup, well one of my friends dad helped me out. I gotta check on the wiring for the big three cuz the lights dimmed a little bit though at idle when i cranked the system, or is that normal becuase i was in idle? I'm gettin my amp back next thursday ish(it was sent back about 3 and a half weeks ago cuz it was messed up)
Username: Suleman36
Post Number: 1352
Try running a 1 farad capacitor and see if that helps. usually with a good electrical system a 1 farad or 2 really helps the dimming.
Username: Rhassler
Gilford, NH
Post Number: 259
yeah, I was thinkin that,but leaning towards that Batcap 800
Username: Suleman36
Post Number: 1354
Thats funny, i actually own a batcap model 800 but havent installed my whole system yet. Waiting on a car.
