Mo. need help making a box or buying one.
Username: Shutterleftopen
Columbus, Ohio United states
Post Number: 37
i'm getting an IDmax 12 in a few weeks and would like either a new box or learn how to make one.
if i choose to either buy or make one. sealed or ported? what kind of wood? how thick? i've never made one before. the help would be appreciated.thanks.
Username: Insearchofbass
Post Number: 2159
congrats josh youll be very happy you made that purchase of the idmax 12
Username: Solacedagony
New Jersey US
Post Number: 448
I'd say sealed, MDF, 3/4" thick. You might be able to contact ID about plans or at least specs for the box.
Username: Velk4425
Post Number: 34
I'd say ported, MDF, 3/4" thick. Matter of opinion and sound taste.
Username: Subfanatic
Walton, Ky
Post Number: 3704
im with jake, sealed
Username: Suleman36
Post Number: 1323
Nope... Josh what you wanna do is (1.8 -- 2.50 cu.ft. vented @ 28Hz)
that will have you covered. I whould recommend throwing 600 - 1000 watts rms to it. Honestly even 600 watts will sound amazing with it. You wont be able to tell much. The SQ will be very nice and you will get alot of low end also. YOu will be very happy.. just wait and see.
by the way you can confirm with Jonathan since he also owns one.
If you can build the box then i whould go to www.woodlawncabinetry.com and have phil build you one.
Post Number: 38
thanks for the help guys. i appreciate it. and what should i do about size? and types of wood? i think i'm gonna look into building my own, since it'll probably be cheaper, i just wanna make it look good and perform well.
Username: Suleman36
Post Number: 1324
Use 3/4 mdf and follow what the size i gave you and tune.
Username: Matt12490
Post Number: 40
how do you change the frequency of the box?
Username: Nnnnick_b
Nc Usa
Post Number: 361
by lengthening or shortening the port.
Lengthening will lower the boxes tuning.
Shortening will raise it.
The ratio between the surface area and the depth of the port is what determines the frequency at which the port is tuned.
