Bronze Member Username: ShadylimitedxPgh, Pa Usa Post Number: 95 Registered: Apr-05 | whats the best hz 2 have far bass travel an how big / long should the port be thankz |
Bronze Member Username: ShadylimitedxPgh, Pa Usa Post Number: 96 Registered: Apr-05 | an also is there a web site that can tell u how many hz ur port is at |
Silver Member Username: ByrumjrPost Number: 226 Registered: Jan-05 | I have my box tuned at 36 hz with 1.1 cubit feet. With only 150 watts you can hear it from 20 or 30 car lengths away. You get the tuning hz by how long your port tube is and also how big around it is. Also it has to do with the box volume. Give me your box volume and what you want it tuned at . I will tell you the size and length for the port. http://www.the12volt.com/caraudio/boxcalcs.asp http://www.carstereo.com/help/Articles.cfm?id=31 |
Silver Member Username: AraknidBOCA , FL U.S. Post Number: 570 Registered: Nov-04 | 27-35 is where you wanna be. |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 103 Registered: Apr-05 | my box is long 24in high 13in an depth is 17.5in thats the outside an its made by 3/4 an the port is now at 3wide high 11.5 by 20.5 long an the cubit ft is 2.396 i dont care bout sq i just want the bass 2 travel like the other guyz systems that come down my street an it sounds good thankx |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 104 Registered: Apr-05 | 1 of u just tell me how long should my port be at 27-35hz i just want it 2 travel farrrrrr lol |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 118 Registered: Apr-05 | tell me how lol |
Gold Member Username: InvainMichigan United States Post Number: 2652 Registered: Aug-04 | The lower the frequency, the further the sound waves will travel. Lower frequencies have longer waves, and longer distances between each wave, so they take a longer time to travel, and travel further. |
Silver Member Username: ShadylimitedxPgh, Pa Usa Post Number: 119 Registered: Apr-05 | how long should my port b 3wide 11.5 high an how long at like 27hz there a web site |
