Anonymous | not shure what i should get have around 400 to spend. found 4 10 inch infinity's 1030w's that i was thinking about. |
Gold Member Username: InsearchofbassPost Number: 2128 Registered: Jun-04 | 400 for just the subs? |
Anonymous | yes, that is my max but it would be nice to spend less those ten's i mentioed would only run me like 280 which would be nice but don't know how they are. |
Gold Member Username: InsearchofbassPost Number: 2132 Registered: Jun-04 | you can do the image dynamics id max 12 for that kinda money heres the site just search on their site when you get there with the words image dynamics http://www.carmedia1.com/ Image Dynamics IDMAX12D Subwoofer $ 279.00 Select Voice Coil Dual 2 Ohm Dual 4 Ohm V.3 12" SUBWOOFER 1000 WATTS RMS 2000 WATTS MAX POWER DUAL 2 OR 4 OHM VOICE COIL SENSITIVITY: 93.6dB FREQUENCY RESPONSE: 50-100HZ RECOMMENDED SEALED ENCLOSURE: 0.65 TO 1.3 CU. FT. RECOMMENDED PORTED ENCLOSURE: 1.5 TO 2.0 CU. FT. SELECT DUAL 2 OR DUAL 4 OHM VOICE COIL IDMAX12D Weight: 35.00 lbs sean Gold Member Username: Insearchofbass Post Number: 2074 Registered: Jun-04 Posted on Sunday, May 22, 2005 - 03:23 pm: -------------------------------------------------------------------------------- thats an excellent sq sub with decent spl sean Gold Member Username: Insearchofbass Post Number: 2075 Registered: Jun-04 Posted on Sunday, May 22, 2005 - 03:25 pm: -------------------------------------------------------------------------------- the image dynamics will get low and clean sean Gold Member Username: Insearchofbass Post Number: 2076 Registered: Jun-04 Posted on Sunday, May 22, 2005 - 03:26 pm: -------------------------------------------------------------------------------- it can go down to like 20 hz that listing is wrong at 50 hz |
New member Username: TraymannsplTrenton, Mo USA Post Number: 7 Registered: May-05 | 4 10s would hit harder if you had the right stuff to push them but the way you talk about money issues you prabbly dont but i would look at 2 15s same surface area as 3 10 easier to push and prabbly cheaper good luck |
