Good amp to run infinity kappa perfects
Username: Mcazayoux
New roads, La United states
Post Number: 90
what r a few good amps to run these speakers?
Username: Robste15
Post Number: 13
an amp that is 70-90rms x2@4ohms such as Rockford Fosgate Power T5002 amp which is rated at 75x1@4ohm rms that should make them kappa perfects sound good
Username: Robste15
Post Number: 14
75x2@4ohm...sorry
Username: Mcazayoux
Post Number: 91
sry im not sure if robert is as experienced as some of u other guys. does anyone have any suggestions? thanx
Username: Skyliner17
Saint Paul, MN United States
ppi a300.2 or ppi pc2300. 75wattsx2 @ 4ohm at 12v so you'll get around 100wattsx2 in the car. Thats what i'm running mine off of.
Username: Shekei
Post Number: 36
Any other ones I cant find those ones vincent. Im looking to
Post Number: 35
look into mtx, jbl, or if u have the cash get the zapco reference 350.2
SweetRide
I have two pairs of the Perfect 6.1's and power them with an Orion 8004 amp.
SweetRide
Username: Molaq
Waltham, MA USA
Post Number: 22
Check out the MTX Thunder 342 or 502 at sounddomain.com. They are very reasonably priced right now, i believe because they are the old model line. MTX amps consistently get strong reviews on this forum.
Username: Shekei
Post Number: 41
Jeffrey. Would the components sound different with the 502 rather then the 342. The 342 is around 100 american the other one is 200$ american. Thanks
Username: Molaq
Waltham, MA USA
Post Number: 23
Tay, the difference between the two amps is how much power they can provide. The 502 is rated 125 watts x 2 channels @ 4ohms while the 342 is rated at only 85 watts x 2 channels @4 ohms. I believe the kappa perfects are rated at 100watts RMS which is right in the middle of these two amps. I would lean towards the 502 but I don't have any personal experience with this set of components. Also the sounddomain price for the 342 is $130 while the 502 is $175.
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 578
I have the 6.1's and I fed them 110 watts and they started to burn up. I suggest only running speakers at 85% of their RMS.
Username: Msully701
Stratford, Connecticut US
Post Number: 128
I have a kicker kx350.2 running to my kappas, set them to +5db and they will take the 110 watts like a champ
