1997 Mustang Svt Cobra Mach 460 Audio Question
Username: Mrclean7913
Gurnee, Illinois
I just purchased a Mustang Cobra and it has the 1997 mach 460 audio system.
6 speakers and there appears to be 3 amps.
two in the trunk and one under the cd player.
None of the speakers work except for the two tweeters on the side mirrors. I would greatly appreciate it if someone would let me know what is wrong or could be wrong or where to look for a connector.
I am guessing that the previous owner had other amps and unhooked some wires.
Thanks
Username: Daddy_phat_sack
Post Number: 65
wat kind of speakers (size) are they????
Gurnee, Illinois
The 2 front tweeters are aprox. 2 in
the 2 door speakers are 6 1/2
the 2 rear speakers are 6x9's
thanks
Username: Johnnyboy73
Houston, Tx U.s.
Post Number: 12
check the amp behind the radio and make sure all 5 harness are plugged in. if they are, you can buy and amp ionnegration harnedd to take care of it all. if that doesnt work, just buy a 4 channel amp and rewire that car
Username: Zero43
Kyle, TX USA
Post Number: 15
Ive had the same experience with an infinity stock system. If i were you I would start by getting some cheap $5 speaker and see if the speakers are just blown out.
