What subs
Username: Shawnomak
HB, SK Canada
Post Number: 41
what are some good, cheap subs. Maybe 10's or 8's. Good sq but also spl. Dont have alot of room and its a small car.
any help is great
thanks
Username: Subzer0
Richmond, KY USA
Post Number: 50
RF or audiobahn.. are really cheap.. and ok thumping for their pricetag, check ebay <-- you can get some 8"s for less than 20 dollars.
Username: James1115
Wilton, Ct
Post Number: 3158
you can get Resonant engineering RE 8's for $40 they sound nice and will get loud for 8's
Username: Alastaka
Post Number: 31
i like rockford stuff id go with p2's i had 2 p'1s and they were loud in the truck but tht was it the p2's are twice as powerful i believe and shouldnt cost more then 70 a pair on ebay for 10's but it depends on what amp your running too. what kinda space do you have to work with
