Box for maaaa avalanche
Username: Hdubb
Farmington, Nm Usa
Post Number: 1515
hey what would you guys think if i threw my ava 15 in a 6 cu ft box, vented. i havent got the tuning yet, to be honest im not really sure what it will be tuned to....sean and joe i need your help
Username: Insearchofbass
Post Number: 2032
what type of sound do you want out of it sq spl or mix?
Username: Hdubb
Farmington, Nm Usa
Post Number: 1516
here are the internal measurements
34x22.5x15
my port is going to be an L shape which is 4.5 wide and i think 8 inches long, (if that makes any sense) and my vent opening is goin to be 5 inches and at the choke area 4.5. well i havent made it yet so this can change.
Username: Hdubb
Farmington, Nm Usa
Post Number: 1517
im looking for deep low bass and sq, i want to hit low notes like 27hz, i know it will be loud so im not really worried about that, i just need to get my port tuning low enough, i dont know the formula to get it though
Post Number: 2033
do you know the displacements for that sub? I came up with 6.64 cf for those measurements
Username: Hdubb
Farmington, Nm Usa
Post Number: 1518
umm no let me check. couldnt find it, its 7.875 deep though that might help.....
Post Number: 2034
ok if we do 34 x 20.5 x 15 internal well have 6.05 cubic feet and assuming it takes up .20 for sub displacement were where i want to be 5.85 cf
Username: Hdubb
Farmington, Nm Usa
Post Number: 1519
can you find out my tuning? and what is the equation for that
Post Number: 2035
is the 15 number your depth?
Username: Hdubb
Farmington, Nm Usa
Post Number: 1520
heighth, my depth is 22.5, its a biggin
Username: Hdubb
Farmington, Nm Usa
Post Number: 1521
oh and im using 3/4 mdf
Post Number: 2036
lets make your port 11.5 high and 2 inches wide your internal depth will tune the port to 20 hz since its 20.5 deep plus .75 for the wood comes to 21.25 inches deep at 5.85 cf. after sub displacements this is using 34 x 20.5 x 15 internal (35.5 x 22 x 16.5 external using .75 mdf) what kind of power you going to run to this
Username: Hdubb
Farmington, Nm Usa
Post Number: 1522
ha i think it is around 28hertz good enough for me
Post Number: 2037
with a box this big and a nice sq curve id do the 20 hz tune....plus i wanna hear from you what 20 hz sounds.... slash.. should i say feels like lol
Username: Hdubb
Farmington, Nm Usa
Post Number: 1523
oops didnt see thqt post when i made mine. well i put my numbers into a calc at carstereo.com and it tol me that it will be tuned to 28 hertz which i feel is low enough, do you? and im goin to be using my brutus 1500, but ill water it down so i down f*ck it up, no 1500 watts to it,
Username: Hdubb
Farmington, Nm Usa
Post Number: 1524
actually i think i might tune it that low.
Username: Hdubb
Farmington, Nm Usa
Post Number: 1525
well im not sure about 20 but 25 i only need to add on 10 inches to my port area
Post Number: 2038
i saw the 1500 only has like a 50 amp fuse am i right? if so your prob only going to be putting a true 432 watts into it
Post Number: 2039
opps its calss d so its 576 watts at 50 amps at 14.4 volts 20 percent loss
Post Number: 2040
i found it its 80 amp fuse ill do the math
Post Number: 2041
1152 230.4 at 20 percent loss equals 921.6 watts but the amp never reaches full fuse rating so your fine
Post Number: 2042
my guess is your going to loose some power anyway from voltage loss so youll be fine at 20 hz and it will be a very balanced tune for the box
Username: James1115
Wilton, Ct
Post Number: 3107
Hunter if you can tune it to 20htz with a FS of 15.7 you are gonna want that 20htz tune trust me:-)
Post Number: 2057
yeah and i want you to tell us what 20 hz is like. Its gonna shake shake shake the inside of the car im sure. lol Im gealous now. I want to experience the 20 hz effect.
Username: Hdubb
Farmington, Nm Usa
Post Number: 1526
ill tell you guys what, ill build a few boxes and i will do some comparing :-) 20, 25, and umm 40 and ill give some results
Post Number: 2136
hunter.....just do swappable ports on that box and youll only have to build one box...or you could do my adjustablable airspace box along with sealed and ported options
