Ok, this is my second system, first one got stolen. This one is going in a:
1993 Toyota PU Standard Cab.
Basically right now I'm trying to decide if I should keep the current subwoofers, or if I should upgrade. My style is clear crisp and tight, I don't need pure power/boom.
Does atlas have a decent 8 or 10 ? thats about all I can fit.
werd
look into image dynamics if you want clear crisp sounds. One of their models comes in an 8. And you can get the IDQ in 10. Or even 1 10 IDMAX would be awesome.
I would go with sealed on that because they generally have better SQ and require less internal volume. Just make sure you use the recommended box size for the sub.
