Sx vs xxx
Username: Trev87
Glennville, Georgia Usa
Post Number: 66
ok i wont deep chest pounding car shaking bass that i can really feel so what would be the better sub for this?
12" RE SX ran off an ED nine.1
or
12" RE XXX ran off an ED nine.1
if u need more details to fully answer me let me know
i also want to know y the xxx and sx are kinda cheap but they are sum of the best subs out there but then the 13w7 is like $700 is it any better than a xxx?
werd
the w7's are more expensive because of the name. I havent hear both of those subs so I can only guess that the x.x.x will be louder.
Username: Mr_kebo
Albertville, Al USA
Post Number: 232
the spl from the SX and X.X.X are very similar, the X.X.X pulls ahead in the SQ department tho. ANd yea with the JL you are paying alot for the name
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 401
you takith my namith....
Username: Trev87
Post Number: 67
so is the xxx compareable to the 13w7?
and i guess the xxx would be better for the question i asked then?
Username: Trev87
Post Number: 68
so is the xxx compareable to the 13w7 if so is it better?
Post Number: 404
well some dont like the way a 13w7 sounds... and therefore prefer the x.x.x ... they are about equal in SPL.... i would get an x.x.x unless you like name brand stuff then go JL... i personally love JL so i run their componants and amps, but i couldnt resist the performance to price ratio of the avalanche
Username: Trev87
Post Number: 69
ok thanks im going to get the xxx then
Username: Hdubb
Farmington, Nm Usa
Post Number: 1448
the 13w7 will be louder though, they are exspesive but they also perform, and with a 13 you can compete with 12s so you have an advantage
