Stop The Rattle.
Username: Bulldawg
Alright, I have a 2000 Ford ranger decked out in explod. I am running a 1200 watt amp with 2 1100 watt explod subs. The bass is great but there is so much rattling in my truck it sounds like crap. are there any secrets to cutting back on the rattle?
Username: Marley289
Post Number: 166
dynamat
fiesta boy
dynamat is good
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1300
dynamat is expensive
eDead is a lot cheaper and close to the same stuff
