INFINITY KAPPAs
Username: Safa19
Post Number: 21
i just bought the infinity kappa 63.5i and 693.5i speakers and they all came with external crossovers... do i only use them if i am using an amp or do i still use them without an amp hooked up? thanks for the help
Username: Mikechec9
Chicago/atlanta
Post Number: 45
use an amp. but use the x-overs regardless. unless you have an active x-over in the hu you are masterful with.
