JL 12w6v2 / Questions
Username: Suleman36
Post Number: 1207
Hey james what amp did you run your 12w6v2 with in that slot ported enlosure and what car did you have it in?
Im having mine built right now to 1.5 cu ft. tuned to 32hz and i will run it off my crossfire vr1000d amp at 500 x 1 @ 2 ohm
Username: James1115
Wilton, Ct
Post Number: 2908
I ran mine off of my PPI a600 at 8ohms in 1.75 cu/ft ported to 30htz.
Username: Suleman36
Post Number: 1208
how many watts were you pushing to it at 8ohms and how did it sound man..
Username: James1115
Wilton, Ct
Post Number: 2909
300 watts and it sounded great.
Username: Suleman36
Post Number: 1211
what kind of music do you usually listen to?
Im mainly into RAP
Username: Suleman36
Post Number: 1231
Hey james how many decibals did you hit with the JL 12w6v2 ported and how many decibals did you hit with the Avalanche 15 sealed ?
Username: James1115
Wilton, Ct
Post Number: 2930
i didnt measure the 12w6v2 but I have measured my avalanche when i first put it in without much tuning and i hit 146 I plan on going back to get it metered again because I have messed around with it since I got it put in and it is noticably louder now so I am really kinda interested as to what I would be hitting but I really dont care much about SPL #'s because thise sub sounds great with all types of music. I listen to alot of old Rap and Country,Rock,Reggae,ska,and punk so I am all over the musical spectrum and the Avalanche performs well with all of them but it really shines with the deep low notes with rap and country:-) Also Mo the avalanche was much much louder then the 12w6v2.
Username: Suleman36
Post Number: 1243
Thats interesting because i wanna compare the 2 since i own both. Its nice to know that youve heard both so i can get some feedback off you. Im really curious cause once i get my box i wanna hear the differance between 2 sealed 12w6v2's and just 1 ported 12w6v2!! Thats mainly what im looking for before i decide to sell it or not.
by the way do you still have your 12w6v2's?
Username: Suleman36
Post Number: 1247
146 is nice considering its sealed / what amp did you use to get 146 ?
Username: James1115
Wilton, Ct
Post Number: 3005
my Orion! yes I still have wy 12w6v2.
Username: Suleman36
Post Number: 1249
Once i get my Avalanche 15 sealed im gonna push it with my CrossFire VR1000D amp which will give it 1000 x 1 @ 1 ohm tested at 12.5 / birth sheet has it tested at 1332 x 1 @ 1 ohm with over 12.5 volts on a good electrical system most likely. Either way i should get in the 140's. They are good subwoofer amp.
But before i set it up with the Avalanche 15 im gonna run that same Crossfire amp with that JL 12w6v2 ported at 500 x 1 @ 2 ohm tested at 12.5 also and see how it sounds like. My box is tuned to 32hz so should i use my SSf and if so what is a good tune for the SSF?
Username: James1115
Wilton, Ct
Post Number: 3011
27-28htz should be good. That box is gonna sound nice with that amp man:-)
Username: Suleman36
Post Number: 1252
Ok i will let you know how it turns out. Also keep me posted on your Ascendant Audio Sub Comparisons
Username: James1115
Wilton, Ct
Post Number: 3015
I will man
Username: Suleman36
Post Number: 1261
Hey James at what frequency did you hit 146 db's ?
Username: Suleman36
Post Number: 1262
Username: James1115
Wilton, Ct
Post Number: 3034
45htz test cd
