HI I'M SETTING UP MY SYSTEM AND I HAVE THESE TWO AMPS THE ORION 225 HCCA DIGITAL REFERECE AND THE 2100 HCCA COMPETITION AMPLIFIER AS WELL BUT I DON'T KNOW THE FUSE RATINGS FOR EITHER OF THEM SO ANY INFORMATION WOULD BE REALLY HELPFULL AND I ALSO HAVE A DUAL FUSED POWER DISTRIBUTION BLOCK ,IS IT POSSIBLE TO HAVE TWO DIFFERENT AMPERAGE FUSES ON IT ? SINCE EACH FUSE GOES TO A DIFERENT OUTPUT THANK YOU
The fuse size for HCCA 225 is 35A, HCCA2100 is 120A. You can mix 2 differenct sized amps under one fuse system, but it would be better to have separate fuses for each amp.
