Need help choosing an amplifier????
Username: Smokingunz23
I recently bought a new Solo-Baric L7 12" and was wondering about some of the possible alternatives I could use for this single sub in a Lincoln LS. I am under a semi-tight budget so if someone could give me some options it would be very helpful. I don't know much about amplifiers..
Username: Mikechec9
Chicago/atlanta
Post Number: 31
d-class amp will drive your sub more efficiently than a class a/b amp. no worries about power draining your system or amp overheating. mb quart makes good amps wheather you go 800 watts or 1000 watts (crutchfield on blowout). and of course you will get plenty of audiobahn hits. what is the (ohm) impedence of your sub? you might try doing a search on this subject also. a bunch of good info already exists.
