Dose push pull sound louder then just 2 subs
Username: Kickeralltheway
i have a question does push pull sound louder then just 2 seperate subs because me and my bro are arguing about it thanks
Username: Subfanatic
Walton, Ky
Post Number: 3562
hmmm, actually im not sure it if would make any difference at all, mabye 1 db lol, not worth the argument, but i would personally say no, becuase i would never put my subs in danger of what you would be doing push pulling
Username: Jonathan_f
GA USA
Post Number: 3935
Isobaric (push-pull) is equivalent to a sealed sub with twice the motor strength, and the same SPL as a single sealed sub, making it less efficient since you're doubling the power It is the same SPL as a single sealed sub, the only use for them is to use a smaller enclosure volume. So no, it won't be as loud as two sealed subs, actually it'll be nearly 6db down.
Username: Sploosh56
Ohio
Post Number: 596
i always thought them kind of set ups had a nice sound and punch to them
