Is this a good deal?
Username: Dano9258
Post Number: 41
Rockford Fosgate 10" Sub i found at http://www.reviewedonline.com.
It's listed at $50(brand new), is this high, low, or just about right?
Punch STAGE 1
4 ohm 10" Component Subwoofer
molded polypropylene woofer cone
frequency response 20-200 Hz
power range 50-150 watts RMS
sensitivity 85.5 dB
top-mount depth 4-15/16"
sealed box volume .65 cubic feet
ported box volume 1.25 cubic feet
Username: Skyliner17
Saint Paul, MN United States
Post Number: 83
if i were u i'd rather get an Ascendant Audio Atlas. just $50 more and probably be much better than that sub. alot of people on this forum would probably agree too.
Username: Dano9258
Post Number: 43
Really? I heard that Rockford is really high quality products. Thanks for your input.
allende5
I don't know much about that sub, but just by looking at the power range, I would rather go with something else. I like Alpine, because it's what I'm familiar with. For $90 +shipping on Ebay, I much rather have the Type-R 10". The Type-R is 500W RMS and sounds sweet. Of course, you'll need more juice to push it.
I'm sure there are pleny other choices as well. I hope you get more responses.
Username: Dano9258
Post Number: 47
Thanks dude.
Username: Sevin7
Post Number: 136
that sub handles 150rms, that is pitiful, not worth $50.
Post Number: 90
yeah the alpine type r are pretty decent also.
