Jl 12w6v2 with jl 500/5 - how will it sound???
jl system
i'm plannin on running my JL 12W6v2 off the sub channel of a JL 500/5 amp (which i basically a 250/1)
I have a small car so not after huge amounts of SPL, but I do want it to hit hard and sound good
will a 250/1 do the job?
also would I get more out of a 10W6v2 with that amp?
Username: Vtecpower
bump
Username: Adampit
Post Number: 53
I heard a 12W7 with JL 250/1, and it sounded decent. Im sure the w6v2 will be fine, even though you are underpowering it.
Username: Suleman36
Post Number: 1238
Just but the 12w6v2 in a ported box and you should be good to go with 250 watts.
