Bridging amps
Username: Safa19
Post Number: 22
hey, i need help with my amp situation. right now i have the audiobahn a8002t amp which is 4oowatts x 2 at 2ohm, i have it powering 2 audiobahn subs and i want to upgrade the subs, so if i got another amp, the same one, would i be able to bridge them togeather and get 800 watts for each sub? or would they not work togeather like that. im new to figuring out amps and need help so any feedback would be awesome thanks.
Username: Tragedy
San Jose, CA
Post Number: 262
You want 800rms to each sub and your going to buy another A8002T amp?
If thats the case just bridge 1 amp to each sub.. the A8002T if it puts out 400watt x 2 @2ohm.. it should be stable 4ohm bridged with an output of 800watts.. just what your looking for. Will you actually get the 800 watts out of that amp is another story.. but at least thats what they tell you, you get.
