How Do Orion H2 Compare to Brahma and JL W7
Billy55555
Anyone can tell me how these all compare? The Orions are the cheapest but all look like very sturdy subs, probably going with a 10 inch at around 1500 rms at one or two ohms. Anybody? I am leaning towards the Orion as they are pretty massive and are the best price ( CBRstereo.com) Sounds like a good deal but I wanted to run it by you folks first.
Thanks!!!
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 651
Sq qill go to the brahma. And spl is hard to tell between the 3 subs, but i think the W7 will take home the trophy in spl. But all of them will be loud enough to satisfy just a bout anybody. And it depends on the box you build also. and 1500wrms is alot for a 10" w7 and also for a brahma. i think it will void te warranty. So with that power i would go with orion H2
Username: Daddy_phat_sack
Post Number: 23
how much are the brahma and a h2????
Miami, FLORIDA USA
Post Number: 659
i believe for the H2 its aournd $300. Not sure on the new brahma pice though.
Post Number: 24
oh..... well..... thats well out of my price range..... SUX BEIN POOR!!!!!
Username: Rds11
Louisville, Kentucky
Post Number: 239
Orion H2 is 280 at CBRStereo.com for a 12". the New Brahmas are 420 shipped for a 12".
Orion H2 is only sub out of those three that can handle 1500 watts. I heard a 15" H2 and it had massive SPL, but then again it was a 15. SQ isn't great, but it will shove
