8ohm sub
I have 1 kicker Comp 12" that is SVC 8ohm. Is there any amp i could use to power this 1 woofer since its 8ohms. BTW it rms at 150watts
Username: Invain
Michigan United States
Post Number: 2414
Any amp would run it at 8 ohms. Just find something that pushes about 300 wrms at 8 ohms. It doesn't matter if you increase the ohms, any amp can run with a higher number. It's when you get into 1 ohm and lower that some amps aren't stable.
Username: Mr_kebo
Albertville, Al USA
Post Number: 224
So if i find an amp that ca do about 300 at 4ohms i will be ok? is that what you are saying?
Username: Invain
Post Number: 2418
Yes.
Username: Mr_kebo
Albertville, Al USA
Post Number: 225
http://www.woofersetc.com/product.asp?0=362&1=363&3=2158 How about that?
Username: Invain
Post Number: 2419
Try to find an MTX 801D off ebay.
Username: Invain
Post Number: 2420
This would probably work too. I know you probably don't wanna spend much on the amp - http://www.woofersetc.com/product.asp?0=217&1=595&3=1941
Username: Mr_kebo
Albertville, Al USA
Post Number: 226
im just looking for the cheapest way to do this, but with something that is still decent,thats why i looked at MTX. This is for my mother :-)
Username: James1115
Wilton, Ct
Post Number: 2936
thats a good amp because if you ever decide to get another one down the road you can wire it down to 4ohms and use the same amp.
