i just got my amp yesterday and i was wondering if i should hook it and my subs up with out amping the stock speakers, or should i just wait till i get after market speakers for my car to hook everything up.
Na go for the hookup man. Make sure your stock speakers are only putting out Highs and near to none bass. That way they wont distort at all and you can crank it up with ALOT cleaner sound. Bass n highs seperate.
bass blockers are you best friend get some from a shop who knows what to give you.....youll find that if you do this they can handle alot more power and stay clean much easier just as pharoh said....in the past ive done stock speakers with just subs and an amp....in some cases if you go too cheap replacement wise for the stock speakers they wont sound any better off the headunit
