6x9...
Username: Killer44
Ontario Canada
Post Number: 138
what would be some pretty good 6x9's to run off a head unit(not sure which one yet)...im looking for some that are not to expensive but still sound good...also would the 2 6x9's(run off the headunit) be loud enough to be hear over the subwoofers(most likely 2 12's about 150-300wrms each)..thanks in advance
figment412
Your not going to have the best luck with that running off of your HU, your best bet is to look for a speaker with the highest sensativity.
