Bronze Member Username: KitkattPost Number: 27 Registered: May-05 | been trying to get box help/info for my new ID Max 12...going in ford escort (yeah, i know...) trunk getting 800 wrms at 2 ohms. want to build slot ported box, but need advice. they recommend a 1.8-2.5 cu ft box vented @ 28 Hz. can anyone suggest dimensions and port size? one port or two? what size is best for the range they suggest? want good sql dumb question...what is "infinite baffle"??? by the way, i had a hard time finding free program to download for mac, and that's as specific as i've found from id, no actual dimensions |
Gold Member Username: CarguyPost Number: 2934 Registered: Nov-04 | Bonnie, try www.bcae1.com. It should answer all if not most of your questions. |
