New member Username: Viperhockey77Post Number: 1 Registered: May-05 | hi just bought a call (mazda mx-3) and i have an alpine mrv-f340 need to know what gauge of wire i use from my battery to the amp? Then was wondering what kind of subs i should buy.that would run off my amp. |
Bronze Member Username: Alias747Post Number: 48 Registered: Apr-05 | That isn't a very powerful amp so you could probably get away with using an 8-gauge amp kit. But if I were you I would just invest in a 4-gauge kit right now just in case you want to upgrade your system. If you don't have any wiring at all go to: www.knukonceptz.com Get their Complete 4-gauge Amp Kit. It has Everything you need to get started. It is really nice stuff too. And at $31.00 bucks, the price is UNTOUCHABLE. Period. As for running subs off that amp... your gonna have to go with something real small because that is a 4 channel amp. When bridged it only puts out 130w RMS @ 4-ohms. 4 channel amps are more for amplifying speakers. |
