Best way to set up my amps,speakers and sub?
jambtt
i need to know which is the best way to set up my system.
I have 7x10 rear speakers, 5x7 front speakers, 10 inch JL audio sub, MTX RT404 amp (specs below) and a MTX RT251D amp (specs below):
MTX RT404 amp:
*Power output:
37.5 watts RMS x 4 (4 ohm load)
75 watts RMS x 4 (2 ohm load)
150 watts RMS x 2 (bridged mono, 4 ohm load)
*Frequency response: 20 Hz-20 kHz
*THD: Less than 1%
*Signal to noise ratio: Greater than 100 dB
*Dimensions: 9.75" W x 2.1" H x 11.5" L
*Regulated PWM Mosfet power supply
*Defeatable 85 Hz 18dB crossover, selectable for low pass/high pass operation
*Smart-Engage auto turn-on/turn off for easy integration to head units
*Real-time computerized protection circuitry
*2 ohm stereo stable
MTX RT251D amp:
* Semi-regulated power supply causing output to increase as voltage does
* 20 Hz--85 kHz frequency response
* 100 watt @4ohms, 200 watt @ 2ohms
* 18 dB/octave crossover
* 8 inch W x 9.75 inch H x 2 inch D
I am wanting to have the RT404 push the 4 speakers and the RT251D to push the sub, is this a good setup? I listen to a lot of rap/hip hop i want a good hard clean thumping bass that shakes my mirrors so i cant breathe.
What settings should i have my installer do?
Appreciate the feedback in advance :-)
