Sound Stream question
Username: Monkey_man
Post Number: 29
Currently, i have two alpine type e's hooked up to an alpine amp that is 600 watt at 2 ohms. I am thinking of evenually upgrading to just one sub that hits louder. I was thinking about the SPLX-12. I no it's very spendy but eventualy i could come up with the money. So, basically i just want to know if this sub will be a good upgrade and if my amp will power it well. Thanks
Username: Insearchofbass
Post Number: 1942
what size type e's my cuddy has a pair of those slammin
Post Number: 1943
buddy
Username: Lotus
Omaha, Nebraska
Post Number: 36
lol, I was like... "ooh a cutlas" then I read your next post :P
Post Number: 1944
lol yeah sorry
Post Number: 30
mine are 12s. Are they really that good? i thought they were just okay cuz i havent set them all the way up yet
Post Number: 1945
in the right box they can be
Post Number: 31
What kind of box does your friend have?
Username: Lotus
Omaha, Nebraska
Post Number: 42
exactly, what kind of box do you currently have them in?
Post Number: 32
i have them in a sealed box that i made myself. I'm thinking i should have baught a ported but hella ppl i talked to said that sealed is the way to go if u listen to rap.
Post Number: 1946
what size do you have them in?
Post Number: 1947
if you want a good box for them do 5.4 cf internal and put 6.25 pounds of fiberfill in and port it to 36 hz with two 4 inch pvc ports 5 inches deep....that will crush your sealed box you have now if you went 1.25 sealed (im guessing you did)
Post Number: 33
Is there a way to make my sealed box into a ported by adding thoughs things above? What does the 5.4 channel and the 36 hz mean? Sorry im new and this is my first system.
Post Number: 34
was i suppose to tune my box?
Post Number: 36
anyone?
Post Number: 37
Is this like a really dumb question or something??
werd
5.4cf is the internal volume in cubic feet. no you cant change your sealed box to ported because I'm sure it isnt big enough. and you tune a ported box, you cant tune a sealed box.
Post Number: 40
okay good i was getting scared for a second.
