Power my 4 10's
I have 4 1030w 10 inch infinity subs that say 250 watts rms and i was wondering what i need to power them. Maybe you could help me find an amp so that i can power these.
Username: James1115
Wilton, Ct
Post Number: 2837
are those subs single 4 ohm or dual 4ohm?
they are single 4ohm
Username: James1115
Wilton, Ct
Post Number: 2841
OK you can wire thos in parellel/parellel for a 1ohm load or in series/parellel for a 4ohm load. Either way you are going to be looking for either a 1000 watt amp at 1ohm or 1000 watts at 4ohms. The major difference is that you are gonna spend more money to get a amp that puts out 1000 watts at 4ohms rather then at 1ohm. For amps do you use ebay?
yes that is where i purchassed my 4 10's. How much would an amp like that run me and what type do you recomend.
Username: James1115
Wilton, Ct
Post Number: 2843
look into Orion HCCA 250g4 to run it at 1ohm or Orion 2250sx to run it at 4ohms actually a guy e-mailed me today and asked me if I wanted to buy his Orion 2250SX if you are interested I can give you his e-mail! I run a Orion 250G4 and I love it.
Username: James1115
Wilton, Ct
Post Number: 2844
also I dont know how much you want ot spend but a jl 1000/1 will work well also.
ya i am kind of tring to keep the cost low. also could i get a 4ch amp and put one sub to each channel.
Username: James1115
Wilton, Ct
Post Number: 2850
I dont recomend it. chances are you wont be able to match the gains and they will be out of phase! I would go with a 2 channel or a mono block.
