05 Dodge Quad cab
Username: Hemiboy
Hello all, First post here. I just ordered a box off of e-bay for some 10's. Anyways it has .68 in airspace and a 7 inch drop. I am having a hard time finding the right subs for this box. Any Ideals? I wanted to cut it square and drop some l5's in it but I dont think it will work. Thanks!
Username: Subfanatic
Walton, Ky
Post Number: 3451
my friend has that truck and box and he put a 500/1 with 2 10 inch w3v2s and it sounds pretty dam impressive for such a nice clean install
Username: Hemiboy
I wanted to go all alpine but the type R's are to big. I have always run kicker subs and alpine decks. I think I'm gonna GO with the Panasonic MXE CQ-C8401U for my HU. The subs are what I was worried about. I'll check em out. Thanx
Username: Xgrizzlyx
Post Number: 94
http://www.cadencestore.com/ProductCart/pc/caraudio_detail.asp?idcategory=24&idp roduct=61
mounting depth is 6.53
they have them both 4 and 2 ohm
or
http://www.cadencestore.com/ProductCart/pc/caraudio_detail.asp?idcategory=25&idp roduct=67
mounting depth 6.5"
both 2 and 4 ohm
