Silver Member Username: DankmanGranger, Indiana United States Post Number: 154 Registered: Jan-05 | Ok i think im just going to keep my subs and get a new amp. what amp would be best for 2 eclipse aluminum 12's. they are 450rms, dual 2 ohm voice coils. i think maybe a 1000x1 @ 1 ohm amp would be good but let me get some opinions. |
Gold Member Username: Suleman36Post Number: 1177 Registered: Feb-05 | what is your budget? |
Silver Member Username: DankmanGranger, Indiana United States Post Number: 155 Registered: Jan-05 | Not more than $350 |
Gold Member Username: Suleman36Post Number: 1180 Registered: Feb-05 | I whould start on ebay and look for a Orion HCCA 250g4 amp or the XTR series amps by Orion that puts out 1000 watts rms. I whould also look on ebay for a Crossfire VR1000D This amp can do 1000 X 1 @ 1ohm tested at 12.5 volts. Birth Sheet has it tested at 1132 rms I have seen them go under $300 |
Gold Member Username: Suleman36Post Number: 1181 Registered: Feb-05 | This is your best bet. I got mine for $429 from www.woofersetc.com brand new. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5773748572 %26%26 |
Gold Member Username: Suleman36Post Number: 1196 Registered: Feb-05 | correction my birth sheet has it at 1332 rms x 1 @ 1 ohm tested at 12.5 volts |
Gold Member Username: Suleman36Post Number: 1197 Registered: Feb-05 | All CrossFire amplifiers are rated at 12.5 volts; however most automobiles maintain 13.8 to 14.4 volts while running. Due to there unregulated power supplies you can expect a 15% - 20% increase in power from 13.8 - 14.4 volts out of all CrossFire amplifiers. |
Silver Member Username: LbecknerTulsa, Ok Usa Post Number: 420 Registered: Oct-04 | you need a 2 ohm stable amp. |
