New member Username: Jcook19Post Number: 1 Registered: May-05 | Where is the cheapest place to get a new, not refurbished, 12" L7? Would it be online or at a swap shop? If online point me in the right direction. |
Silver Member Username: Car_bangsPost Number: 104 Registered: May-05 | www.carstereoexpo.com the sh@t here is really cheap and they have everything. kicker l7 15's f0r 300 bucks 200 factory refurbished |
Bronze Member Username: HellbenderLos Angeles, California USA Post Number: 87 Registered: Apr-05 | http://www.smelll7.com/main.html oops you meant the sub! muahahaha......yeah, I'm bored. |
Silver Member Username: Loc_outPost Number: 148 Registered: Feb-05 | ebay |
New member Username: Jcook19Post Number: 2 Registered: May-05 | so you think ebay would be cheaper (include shipping also) than a swap shop (no shipping)? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39777%26item%3D5772852119 %26 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39777%26item%3D5772193794 %26 would you suggest either of the two? if so, now i need the amp to power it |
New member Username: Jcook19Post Number: 3 Registered: May-05 | which amp? or do you have a better one for the price. the reason i go for the bigger amp is so i don't have to have it up a lot and they aren't the best name brands. maybe i could upgrade to two L7's in the future. lmk http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5773247833%26&sspagename= STRK%3AMEWA%3AIT%26 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5772400953%26&sspagename= STRK%3AMEWA%3AIT%26 |
New member Username: Jcook19Post Number: 4 Registered: May-05 | ok i smarted up i think. if i get the kicker 600.1 amp 600rms @ 2ohms i should get the 4ohm dvc sub correct? |
