Danny Lewis Unregistered guest | will this amp be good for 1 atlas 15"(soundstream van gough)... or should i get a audiobahn a8002t? both same price-audiobahn has a more power 1x800w rms at 4ohms 2x200w rms at 4ohms 2x400w rms at 2ohms and this is the soundstream van gogh http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18796%26item%3D5772841783 %26 |
Silver Member Username: 54danny54Post Number: 253 Registered: Nov-04 | perfect |
Gold Member Username: James1115Wilton, Ct Post Number: 2829 Registered: Dec-04 | for 1 or 2? that amp is way to powerful for 1 atlas an avalanche maybe but not an atlas unless you run 2 of them in stereo! |
Danny Lewis Unregistered guest | which ones are you guys talking about the audiobahn or the soundstream van gogh????? the audiobahn has alot more power but is the soundstream better quality |
Gold Member Username: Taylor17Kopperl, Texas Post Number: 1798 Registered: Jan-05 | Audiobahn. |
Gold Member Username: James1115Wilton, Ct Post Number: 2851 Registered: Dec-04 | they are both to big for an atlas! if anything I would go with the soundstream but 400 watts is gonna be to much but I doubt it really produces those numbers, but neither does that audiobahn either. I would get either a ppi a300, or a JBL bp 300 or a JL 250/1, ir an orion HCCA 250g4 something along those lines will be fantastic |
Gold Member Username: FishyTamarac Ft.Laud, FL USA Post Number: 1261 Registered: Sep-04 | http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64573%26item%3D5773259327 %26%26 Great deal(discontinued new) if you can get it for less than $200. 300x1 into a 4 0hm load and 600x1 into 2 if you ever want to upgrade your sub. If thats too much cash a used JBL BP 600.1 would work and has pretty much the same specs as the Xtant: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5774015942 %26 Otherwise that Soundstream would be ok(be careful with gains and avoid bass boost) and would make a good mid/high amp if you ever want to upgrade. -Fishy |
