Polyfil with right volume
RCT
I am finishing the enclosure for two RF 8" subs. They are in a sealed enclosure that I built to the exact internal volume specs. The chambers are seperate. Should I still use polyfil? and if so how much?
Username: Solacedagony
New Jersey US
Post Number: 404
I'm pretty sure polyfill generally adds 0.1 cuft per pound inserted.
Polyfill helps dampen a little bit and usually makes your equipment sound a little bit better.
RCT
Thanks, I know the polyfil adds to the percieved volume of the enclosure. Thats my question. Since my enclosure was built to the manufacturer's optimum specs, should I still add the polyfil? Or should I skip the polyfil and add some kind of dampening material (ie dynamat) just to the inside walls?
Username: Carguy
Post Number: 2883
Polyfill is better for the box. You don't want to use dynamat inside the box.
RCT
Thanks for the info guys, but maybe I'm not stating my question clearly. I know polyfil "adds" to the internal volume, and that it also has a dampening effect. My enclosure was built to the optimum internal volume per MFG specs. I don't need the polyfil for internal volume, I am only considering it for its dampening effects. The question is, will the benefit of the dampening effect outweigh the detriment of increasing the internal volume above the MFG's specs?
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1245
If you don't want to increase the airspace your subs "see" don't use it, but not all manuafcturers specs are optimum. You might like the way they sound with the polyfill.
Oh btw it IS this "dampening effect" which increases the effective volume. Polyfill can smooth out upper bass as well, but serves no other purpose.
Instead of asking us, just go try it both ways and see which you like better. You may not even be able to notice a difference.
-Fishy
