NeEd To KnOw SoOn
Clueless384732
i need to know this soon because of the limited time.... is 2 15" atlas's going to be better then 1 15" avalanche??? there about the same price( 2 15" atlas-210$/1 15"avalanch 225$) are the 2 atlas's going to be louder and better spl
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 326
i think 2 atlas's are 1 db less then 1 avalanche... not a proven fact that i know of but ive heard it. although u could look at it in a few other perspectives to help you choose.... one avalanche would savee you enclosure space. and 2 atlas's you will need less power so you can save money on an amp
Clueless384732
i was thinking the audiobahn a8002t amp, it puts out 800w rms x1 @4ohm so it would power the ava perfect(i think it's 800w rms) and somewhere i heard the amp power should only be 80% of the wattage of the sub
ex- if i had a 100w rms sub i would have a amp putting out 80 w rms--- and the audiobahn is overated so i thought it would be perfect
