Good or bad amp
what do u guys think of the boss pd-4000 good bad ok or if any of u think the hifonics amp would b betta casue need a 1ohm amp http://a1bigaudio.com/viewItem.asp?idProduct=1718
Username: Tragedy
San Jose, CA
Post Number: 227
Well i would imagine if the Boss amp really put out 4000watts.. 2000x2 @ .5ohm they would charge more than 9 1/2cents per watt. So you bet its too good to be true. Thats unheard of for a quality amp.. generally your looking $.75-1.00 per watt.
In your case the Hifonics would be better.. but then again that depends on your application and price range.. your looking for a 1ohm stable amp.. but what are you looking to power?
Username: Alumaprodave
CALIFORNIA
Post Number: 25
I bet Boss does not say what the distortion % is at 1 or half an ohm.
Username: Tragedy
San Jose, CA
Post Number: 228
5% or more i would bet
